Micrologix 1500, Panelview Micro 300 Programming?
donl517
Dec 2005
Michigan
127
I have the attached two programs and I can't understand how he is calling the panelview screens. In rung 33 of the messages section I'm trying to call the "Missing Heat Stake Fault" (State 4) in the panelview. I guess I'm lost as to how it's being done. I see it as N105:4 but everything he is calling is N106. If any one can enlighten me I would appreciate it.
Thanks,
Don
I am not sure what you are asking, tried twice to respond and messed up so waited a bit to see what others may say.
An alarm screen can be triggered by any bit going high (or low) so not sure what you mean by being called. I could not open your PVA file so did not get to look at the PV program.
its a multi state...
when 105:4/4 is true in rung 33 then that will be your multi state
I saw your pic Ron it was a little off center??
Well that is what I thought but the screen was going haywire when the 105:4/4 bit was high. Also, even though the rung was true and the B3:0/11 was staying solid; N105:4/4 was flickering true/false. Any thoughts on why that would occur?
Thanks,
Don
I see what is going on now; I had missed all the stuff at the bottom of the Message ladder. I have to say this is one of the most interesting programs I have ever had the opportunity to revise.
Thanks Again,
Don
89
Hello, Well, after fighting thru comm and cable issues from pc to panelview and pc to plc finally communicating with each separately. I have...
20
17,856
Hey guys! I need to communicate a PV550 with a Micrologix 1500 ASAP, but the 1761-NET-AIC doesn't seem to be working. I was wondering if the...
5,235
So I figured I'd start off by saying I love this place. I never registered, but frequent this place often to read up on the little tricks to get...
3,345
i have a mircologix 1500 lrp using df1 on channel 1 and i want to talk to a panel view plus using df1 drive i need the pin outs to make a cable...
1,471
