Micro 820 with hmi
cdnrookie
Apr 2013
Canada
112
Good morning guys,
We have a small project that we would like to use an existing micro 820 and proface 3201
Before I spend hours researching the best way to do this, are there any suggestions? I've had a hard enough time just figuring out the 820! I don't find the software to be very intuitive
What is it you are wanting done? I don't know anything about the "Proface 3201" But I have used the 820 with "Modbus Addressing and Ethernet Tags and both function just as they should. We use the 820/810 for all kinds of small project and have had outstanding success.
We just want to monitor some inputs and ouputs on a few machines,
The issue I run into immediately is finding some documentation on the cabling from the 820 to the proface, seems everything is setup for the 850 serial
I guess to be clearer, im hoping for a pinout from the 820 to the proface rs232,
Both have ethernet capabilities, but would like to keep that open
I just got done with a project integrating a Micro 820 into an older re-branded Red Lion HMI. The HMI was installed before the Micro 800s were...
4,818
Hi Folks, I took Baldone's suggestion and ordered a Weintek HMI to try them out. There's a bit of a wait here in Ontario(2-3 weeks) when...
5,020
I’m running a micro 820 to measure a tank level, then turning on equipment at certain levels. I have an analog input (4-20) that I’m storing and...
288
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
362
