Micro 830 Serial to PVc
PurdueKid
Nov 2012
Purdue
I just recently got back from the Rockwell Automation Fair and when I was there I sat in a session on the new Micro 830 & PVc. Previously I have been using the Modbus Mapping but that is being very timly so im looking into the CIP method. Ive been sitting here for a couple hours now and I just cannot get them to connect. I am using a 2080-SERIALSOL module on a micro 830. Can anyone please direct me on how to setup the PLC module and the PVc (C600 is what im using) to talk serially but throught the AB CIP method instead of ModBus.
Thanks to anyone that can help, Ive been searching everywhere for some support and I've found the guys on here are almost always better than what I can get from them!
Dylan
I didn't go to that session, but I've read the CCW 2.0 release notes a little bit and they suggest that the current versions of both PanelView Component and Micro 830 will support "CIP symbolic" communications
Have you upgraded your controller to version 2 firmware using ControlFlash ?
Yea I have the latest firmware on both the PLC and the PVc. What I cant figure out is the communication settings on both of them to get it to talk over CIP. I know the modbus works because I can map it and everything works fine. Im just tired of mapping all the tags so I want to start using the CIP. Ive remade the whole program and pv to run off CIP and now I just cannot get the communications to work. I am just wondering if someone has a general setup or something they can walk me through to make sure im not missing something easy.
Hello friends We communicate between Micro 830 and a card that control DC motor via modbus RTU. We do not have any problems in communication. But...
1,530
Hi, Its possible communicate between kinco hmi (mt4404t) and Micro830 through a serial line ( rs232/485 ) ?
1,574
Customer has a Micro 830 (2080-LC30-16AWB) and a Panel View component C200 (2711C-K2M). They want to add remote connectivity. I was thinking of...
2,725
how do I make a timer timing bit in a micro 830 program using connected components?
1,615
Good Evening , I haven't done much with CCW and the Micro 830. I am trying to upload a unknown program from a Micro 830. It just seems like...
2,812
