Uploading an unknown program from a Micro 830 and going online with CCW.
Aug 2016
Virginia
343
Good Evening ,
I haven't done much with CCW and the Micro 830. I am trying to upload a unknown program from a Micro 830. It just seems like I am going in circles. I select upload , who active comes up , I select USB , etc. It acts like it is uploading , but the connect button is still bold and present . I go and select connect , and then the circle begins . Is there and easy to understand procedure that maybe one of your guys have down. Also , for some reason this small machine builder wrote it in C , it looks like. Looking for the actual values of the analog inputs and other information is a challenge. It looks like "check boxes " for digital input and output status .
Do you folks have and thoughts or links .
Thanks in advance ,
So you have CCW Version??? and a Micro830 connected together with a USB cable - is this correct?? (And the power to the PLC is on)
You should be able to start ccw, then goto file, then DISCOVER - click on discover and after a short while you will get a selections window that allows you to select the communication protocol. Select USB, once you select USB the CCW software should automatically find the PLC and list it as a device that you can communicate with, it will probably say Micro830, highlight it and then click OK.
It will then attempt to upload current PLC program into CCW for you to edit. This will work as long as NO PROTECTION has be put in place.
RS Logix 5000 - Uploading an unknown file. Ask to "Select File" when I don't have one Good Morning , I have a CompactLogix program that I...
2,084
Good Afternoon , I have a HMI application on a Panelview C600 ( 2711C-T6T ). I do not have a copy. I would like to upload the application...
6,860
I have a Siemens laptop with Step 7 connected to a Siemens HMI with Win AC right now. I want to upload to the laptop, but I get an error: "Online...
3,704
How can I access the web page that allows me to see and upload the pcl or translation file into my Pl1000E? My Pl1000E doesn’t have an ethernet...
136
Hi guys, I have had some issues with uploading a program from a Micro 850 PLC. This is the first time connecting so I don’t have a file on my...
303
