Uploading to Siemens Step 7... CPU Unknown. (I'm on-site right now)
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
I have a Siemens laptop with Step 7 connected to a Siemens HMI with Win AC right now. I want to upload to the laptop, but I get an error:
"Online CPU Type 6ES7 671-7EG00-0YA0 V4.0.0 unknown"
I suspect this laptop does not have this CPU profile in it's library, but I'm having a hard time making sense of that because the version is NEWER than the original version... "V5.5 + SP3 + HF5, Revision Level K5.5.3.5" versus the original "V5.4 + SP3 + HF1, K5.4.3.1.3.4.0.1, K5.4.3.1"
Can anyone advise what my solution is? I am at the job-site right now.
Thanks,
Brian
6ES7671-7EG00-0YA0 is Win AC MP. Here is the manual:
http://support.automation.siemens.com/WW/view/en/26729818
In chapter 3.2 it says:
To be able to use WinAC MP on the HMI device, it is mandatory that you keep to the
following sequence during installation on the configuration PC:
1. Install STEP 7 V5.4 SP 4 or higher
2. Install WinCC flexible 2008 SP1
3. Install WinAC MP 2008
So you need both WinCC Flexible and WinAC MP extension for STEP7.
You were faster to respond than the Siemens Technical help desk! Thanks!
I bumming tonight over compatibility issues... The original project was done in 2007 versions of everything, and the run license on the HMI goes with that. All the software on this Siemens Field PG is 2008 versions, without a new run license. I'm afraid that tomorrow I'll find out that all this work to get the Win AC MP will be for nothing.
While searching for info on the 6ES7671-7EG00-0YA0 I found a service entry stating that all WinAC MP 2007 could be upgraded to WinAC MP 2008 free of charge.
Maybe that is helpful to you.
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
174
Hello there, currently im working on a s7-200 to s7-1200 migration. Thing is that s7-200 has a TD-200 which contains all of the alarms and i dont...
665
I need some clarification about uploading the HMI file from a Siemens MP277 to edit it in WinCC. Although the machine manufacturer is no longer in...
1,354
I'm using a 3rd party USB to MPI adapter cable. I can see 157 blocks of various types listed under Accessible Nodes in Simatic Manager. The Upload...
28
8,210
Hi all, I'm hardly a Siemens expert, and am struggling with a conversion I'm working on right now. A system was purchased at auction, and I'm...
1,857
