Micro Logix 1000 (HELP)
Patrick420
Nov 2019
Mi
Hi all
So I made this PLC learner box with 6 toggle switches and some push buttons I have it all wired up and all set. However I am having a major issue with not knowing which programs to download so I can start programming. Can someone PLEASE PLEASE PLEASE help? I’m pulling my hair out I’m very new to PLC training I know some but barley scratch the surface. If someone can send me a link that has directions or the links I need to download?
Happy holidays
tarik1978, has posted the link for the download, but if I were you.... I would remove the 1000 and install a 800, the 1000's are no longer made and since you are just starting you may want to start with a platform that will be around for awhile, the software is also free
https://www.rockwellautomation.com/...1&pagetitle=Design-and-Configuration-Software
And Happy Holidays to you also!
im using a micro logix 1000 and it has 20 inputs and outputs on it but when i go onto rslogic 500 it only shows 16 how do i use the last four...
2,169
does anyone have any idea where I could get a used micro Logix 1000 trainer used? Or could this be a dumb idea to pursue I look on the net and I...
39
11,274
Hello everybody, I've had an issue with MicroLogix 1000 1761 – L32BWA. Somehow I had shortcut wire from PLC output with COM. Output voltage was...
8,186
Dear All, I am building a small project with surplus equipment to perform a simple positioning task. What I wish to do is to connect two...
2,332
Hello folks, I've been lurking in this forum for some time and find this site to be an excellent resource. :bow: I hope to contribute to it some...
8,099
