micro logix 1100 flasher
Is it proper to use the S:4 instruction ie: S:4/12 for a flasher?
Yes, this is done quite often. Just change the bit number to get the flash rate you need.
One reason I don't like this method, however, is that when you activate the logic to enable the device (usually an indicator light), you will likely catch the S:4 bit "mid flash" and it will cause your first pulse to be oddly timed. Not usually a big deal but those kind of things keep me up at night. So, for flashers nowadays I generally use a dedicated timer activated by the enable logic, and a bit of the accumulated timer value to trigger the light (i.e. T4:0.ACC/12).
Ok thank you very much. Do you happen to know if the lower the bit number, the slower the rate?
Ok Thanks again. Its really nice to be able to ask a question and get a quick response. I like this site!!!!
I just do Old Skool flashers with two timers like the attached pic. Just use the TT... It breaks the boredom of everything flashing at the same time.
I'm working on a project currently that is requiring me to log a username and a and number. I need to MSG a string file, the username, and an INT...
2,078
Does the 1100 only have 1 high speed counter, but it can have multiple inputs? And so then the 1400 has 6 HSC and you have a choice of multiple...
1,723
we have a new machine coming and the company is asking which PLC do we like to install. I need some feed back please. micro logix 1100 or...
1,626
Hello forum, i want to buy a ab plc for practices purposes, where I live , most jobs requires you to have knowledge in rslogix 500 , based on...
4,518
Hi there. I've been an industrial electrician for 6 years straight from school and I'm currently undertaking my first project with a PLC and HMI...
2,545
