Micro master semiens vfd
nibay
Jul 2009
delhi
42
HI EVERYONE,
CAN MM series VFD DRIVES SUPPORT BACnet PROTOCOL OR N2OPEN PROTOCOL FOR JOHNSON CONTROL(METASYS CONTROLLER).
KINDLY HELP ME.:unsure::unsure::unsure:
THANKS JWR,
CAN U TELL ME SIEMENS DRIVE SEND DATA IN MOUDBUS???? IF IT IS WRITE THEN OUR CONTROLLER SUPPORT MOUDBUS and IT GIVEN DATA FROM MUD BUS AND NO ANY CONVERTOR REQUIRED>>>
I successfully got a Micro 820 (Slave) and Red Lion HMI (Master) to work together using Modbus TCP. But now I need to add an Automation Direct...
2,673
Hello Guys, I have two different Micro 830 PLCs, namely 2080-LC30-100QWB and other one is 24AWB. I want to make one Micro 830 as Modbus Slave and...
2,570
replacing this drive is the program and parameters in the saved in the front module it is using profibus for its coms
1,538
Does any actually use Starter and think its any good ?! It takes 4 hours to install on a normal laptop, takes 10 minutes to start up, wont run...
2,296
hi, i want to work as a siemens micro master drive using two analog input choosable, digital input 2 is disenable analog input one select...
2,048
