Spidermite
I am trying to use a Micro820 to communicate with a Solo SL4896VRE
temperature controller. The Solo came from Automation Direct.
physical connections between the 2 are:
Micro820 D+ to Solo D+
Micro820 D- to Solo D-
The temperature controller is set up as follows:
C-SL (Modbus Protocol) rtu
C-no (Network Address) 1
bps 9600
LEn 8
Prty Even
Stop 1
The Micro820 controller serial settings are:
Driver ModbusRTU
Baud Rate 9600
Parity Even
Modbus Role Master (but have tryed Auto also)
Protocol Control
Media RS485
Data Bits 8
Stop Bits 1
Responder Timer 200ms
Broadcast Pause 200ms
Inter-Frame 0 Us
(Delay/Timeout)
The Solo documentation states that the set point is at location 44098
I have included 2 attachments. One is a screen shot of the variables used
and the other is the one rung that is the program.
Once the program is downloaded and I force the trigger, I expect
the Local_Add registers to become populated. All I get are 0's
What am I not doing?
bps 9600
LEn 8
Prty Even
Stop 1
Driver ModbusRTU
Baud Rate 9600
Parity Even
Protocol Control
Media RS485
Data Bits 8
Stop Bits 1
Inter-Frame 0 Us
(Delay/Timeout)
