Micro830 HSC not enabled
JJI
Dec 2018
New Jersey
HI there! I'm new here and was looking for some help with getting my HSC to work.
I have physically connected an encoder to the PLC and it is working properly.
I added the interrupt to the control and linked it to a program as well as assigned it to the input HSC0. I adjusted the input filters for input 0 and 1.
I have inserted the block into the ladder and populated the tags with what I believe to be the correct data.
At this point the block will not enable and only shows a status of "0".
I added a global variable that enables me to change the "command" and even toggling it i can't seem to enable the function block.
Good thing is I realized what the issue was with enabling the box. I had it in the interrupt program.
Now that I have moved it to another program, the box is finally working. Now I just need to take care of the configuration error.
All- I am new to the Micro830 and the Connected Components Workbench. I am trying to wrap my brain around the High Speed Counters. I am trying to...
2,377
I am having issues getting a Red Lion HMI and Micro830 controller to communicate. I am using the cable here to connect the controller to the RS232...
119
Trying to put these equations in structured text program in a Micro 830. when I run the verify I get this error. ;:expected before this new...
444
Having to add some programming to a Micro830. I want to add a free running TON, reset with a done bit. in the drop downs or the instruction...
287
Hello, We have a project on our shop floor that for some reason project management decided to not talk to controls about and pick some...
1,326
