Micro830 Panelview C400 Dual Input Counter
brianmullaley
Jan 2014
PA
I am currently working on a 2 input counter with 2 outputs Filling a box and allowing it to move forward to make way for an empty to get in position. I need to control 2 outputs based on the total count from pulses given by 2 sensors. Please help with any examples, this is my first exposure to CCW and the Panelview interface. I am online with the controls and able to upload/Download.
This was suddenly dumped on my desk with the instruction "Do It" so I'm in desperate need. Thanks
Brian
welcome to the site
you may have to check both the C400 and the 830 firmware
make sure both of these are the latest, assuming they have not been programmed before.
Prior to V4.0 (830) you needed to use Modbus for communications.
now you can use tag based CIP
I will post more info later, but search this site for 830
I am having issues getting a Red Lion HMI and Micro830 controller to communicate. I am using the cable here to connect the controller to the RS232...
127
Trying to put these equations in structured text program in a Micro 830. when I run the verify I get this error. ;:expected before this new...
451
Having to add some programming to a Micro830. I want to add a free running TON, reset with a done bit. in the drop downs or the instruction...
291
Hello, We have a project on our shop floor that for some reason project management decided to not talk to controls about and pick some...
1,334
I have an application using an A-B Micro830 controller. Does anyone have a PDF tutoring how to program one of these. Not very intuitive especially...
23
6,562
