MICRO850 and HSC Counter
PLC Pie Guy
Jun 2013
Halifax
1,144
Hey All.
Starting another little machine project here. I am using this time a Micro850 simply to take advantage of the memory capacity over the 820.
I'm using a 2080-MOT-HSC to grab a pulse count from an encoder. That's great and it all works.
The trouble is..... I really need 2 counters set up reading this encoder. The issue I'm having is that in the V10 release of CCW, it only supports 1 counter per HSC module. The new release, which is a few weeks away yet, will allow 2 counters to look at the same slot. I can indeed create the second counter with all its own parameters, but the UDFBs seem to share the Accumulator and reset together when either FB is reset or "un-initialized".
Has anybody done anything to overcome this???
Just an update to this if anybody else is interested.
Since V10 only supports one counter per HSC Ad On module.(2080-MOT-HSC) Since I'm a bit impatient I had to find another way to make my project work with two counters. I like using the HSC ad on simply for the very nice UDFB that it supports. However, this time I decided to use the onboard embedded HSC inputs. This chewed up 4 inputs but it gives me what I want with two self contained counters looking at the same encoder pulses.
I had never set one up in this manner so it took a bit of toying with the Input configuration and the HSC FBs but it seems to work very nicely. I can reset both counters independently of each other.
We have some Pines Benders that we want to upgrade to a digital bend angle, one of them has a CompactLogix PLC with a 1769-HSC module, but I was...
1,811
I can't get the encoder pulses to show up on the function block when I'm in "de-bugging" mode, which is the on-line mode of the software. I...
7,243
Good day, I have a micro 850 with a 2080-MOT-HSC that is being fed by two flowmeters, Schneider Electric using IMT31's as converters. They are...
461
I was looking at the HSC function block in connected components and was stumped by the documentation on how to address the input for the HscID in...
3,917
I'm having major issues programming the high speed counter function on the Micro 850. I have no more avenues to pursue... I've tried everything I...
8,538
