AB: 2080-MOT-HSC, High Speed Counter for Micro850
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
I can't get the encoder pulses to show up on the function block when I'm in "de-bugging" mode, which is the on-line mode of the software. I suspect it could be the encoder that I'm using. It only has 3 wires, +vdc, com, and A. I'm using a simple "count-up" UDFB. I can see the values change when I enable the counter, and when I "start" the counter, but the "Accumulator" variable stays at 0 when I'm turning the shaft.
More info:
Slot ID: 2
Noise...: 00 (no filter)
Mode: 0
There is so little info on the internet about this card. Can anyone help? I'm very frustrated, and the customer is losing patience. Thanks!
Brian
IMG_20150202_111408582.jpg IMG_20150202_111310814.jpg IMG_20150202_111542698.jpg
Gary,
I've attached the high preset value, it's highlighted in blue in the pic. I even threw in a starting value, just to make sure. The Logical value of this variable is 140737488355326. Maybe I'm confused.... This is the value they're talking about, right?
Brian
danatomega,
Yes, I've read that many times.... The function block in my initial post is the downloaded function block. You can see in the detail of the pic that the PLC has confirmed the presence of the HSC card in slot #2 (IDCheck) and the counter is initialized and is ready to count (Initialized = True).
Brian
Maybe wiring is my issue. Here is a picture out of the manual for wiring the card. I have +24 volts and common going to the encoder..... A going from the encoder to the A terminal on the card.... common going from the power supply to the 0- terminal on the card. Three wires is all on the encoder (see previous picture).
Brian
I know nothing about this encoder or module but looking at your image .....698 I fail to see a connection for the 0 volts on the module to the 0 volts of the power supply. Maybe there is an internal connection that I am overlooking.
I almost looks like you would need an A+ and an A- wire from the encoder. Maybe you could try connecting the A lead from the encoder to the A- terminal on the module to see if that will work. Use this info at your own risk, as I said I am not familiar with either one. This encoder type may just not work with this type module.
Good day, I have a micro 850 with a 2080-MOT-HSC that is being fed by two flowmeters, Schneider Electric using IMT31's as converters. They are...
464
I'm trying to set up a ring counter - one that transitions from 3599 to 0 (and 0 to 3599 in the reverse direction). My counter insists on...
364
Hello everyone. I'm having some error on the pulses read by the HSC card. I'm using the 2080_MOT-HSC as a pulse counter; in the CCW in using...
632
Hello, So I have a Micro850 PLC with a 2080-MOT-HSC Plug-In module, and i'll be using this for an encoder. I think it was version 11 in CCW...
1,994
MICRO 820 PLC - 2080 MOT HSC - Jencoder J-15S-SL Above plc, add on module and encoder are using to configure one paper cutting machine...The...
3,874
