Micro850 Kinetix 300 UDFB
seth350
Jul 2011
Over yonder
373
First time working with a Micro850 in CCW v11.
I have found this document #CC-QS036A-EN-P that details setting up the communication between the two. The problem is that I cannot find the UDFBs the document cites.
The only ones I am able to find is from the sample code page and it was wrote in CCW v4 with DWORD arrays as inputs.
Does anyone know where to get the latest UDFBs for the Micro850 and Kinetix 300?
I downloaded CCAT thinking I could get them from it. However, after it creates a project, CCW won't open it. Seems to be a conflict with CCW v11.
https://literature.rockwellautomation.com/idc/groups/literature/documents/qs/cc-qs036_-en-p.pdf
Thank you damica, I will take a look.
I have some UDFBs for the Kinetix300, but I also need to be able to change the index parameters from my HMI. The UDFB that’s i have to do that wants the index number and other options as a DWORD[1..1]. Seems strange to me. I wasn’t able to convert into a DWORD[1..1].
Go to their sample code library and download (Expand/Merge) for both (Word and Dword) format.
This will allow you to control each bit of the word/dword. This is a great UDFB I use it all the time.
damica, the UDFB you found for me is the same one I have.
The only thing I have an issue with is the RA_K300_INDEX_DATA function block and it wanting the DWORD[1..1] datatype.
Our AB distributor finally got me a copy of the UDFB I was originally looking for. They are sending it over today.
I will look at the Expand/Merge FB you suggest as well.
Will you post the new function block once you get it so I can add it to my library?
damica,
Sorry it took so long, just got the project open. Apparently, if someone creates a CCW project with CCAT and zips it up and sends it to another user, the new user won't be able to open it. The project is looking for files on the creator's PC.
You have to open serveral of the files up in Notepad and edit the file paths.
Anyways, here are the exported UDFBs. This should help others in the future as well. At least until Rockwell fixes this hot-mess called CCW.
damica,
Thank you! You saved me from a big trouble last night. Thanks for sharing!!!:geek:
Dear colleagues, i'm getting into with CCW and micro850 for first time and I need communicate this micro850 with 3 kinetix5100, one scara robot...
2,251
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
76
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
84
HI everyone! I am trying to use a Micro850 to control a SureStep (Leadshine) Stepper drive (DM805-AI) from Automationdirect. I have no trouble...
192
Hi guys, I have had some issues with uploading a program from a Micro 850 PLC. This is the first time connecting so I don’t have a file on my...
329
