Nearbyatom
I'm trying to set up communications between the AB Micro850 and a Delta HMI DOP-107WV. I can get everything working using Modbus TCP. However Micro850 is only limited to 200 tags. I'm running pretty close to it. It looks like Delta software has support for some AB products already (see attached picture), but not the Micro850.
I'm wondering if I can use ethernetIP (controllogix, compactlogix) (use tags). I tried it but it doesn't work. But I might be missing some parameters either on the PLC side, or HMI. I'm not sure. I get a TCP read error 22, no TCP connection.
I'm not even sure if the 2 can talk to each other over ethernetIP. Has anyone given this a shot and made it work before? Let me kow. Thanks!
