MicrolLogix 1000 w/ AC inputs
templets
Jun 2010
davis,ca
I picked up this PLC (1761-L16AWA Series E) surplus and was hoping to play with it some. After buying it I determined that it was 120v AC inputs.
Not sure what to do with that. How would normally such a PLC be used?
I figure at least I could use it to control lighting off the output relays, but what inputs/sensors are AC?
--Steven
any dry contact could be used as an AC input. Or even low voltage if they run a relay.. and use the contacts to the inputs.
This plc can be used in any fashion where you have only 10 inputs and 6 outputs required.
Photoeyes and proximity switches are available that use 120vac. Pushbuttons also can be wired to use 120vac.
And if you want to standardize sensors/switches with other machines that are 24VDC and not 120VAC, you can just use relays with 24VDC coils and put 120V on the contacts to the input.
As has been stated, basically ANYTHING that is available in 24 volt dc versions is also available in 120 volt ac versions as well. If you are going to be playing with it at home, one "input" that is 120 volt would be the light switches on your walls. (Not that you probably want to re-wire your house, but I'm just saying as an example.)
Hello everybody, we have in our power plant micrologix 1400 PLC installed with filter. The main task of these PLC is to: 1-Read via a one...
1,722
I have a microllogix 1100 and I can not conect to it via modbus. The message error code that appear is 1f39h. Is there any way to solve this problem?
1,417
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
160
Greeting! I am new to this area so I am wondering if anyone can help me or guide me how to solve the problem. I inherited projects for plants done...
161
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
153
