Micrologix 1000 1761-L16BWA momentary fault at power up
david90
Apr 2010
ca
202
Is it normal for the fault LED to light up for about 1 sec at power up? The PLC works great and I don't see any obvious problem with it.
All the lights flash momentarily when you power up. (Pretty sure, I don't power down my processors that often, so I'm not used to seeing it).
As long as after power up it remains powered, fault LED is off, and the PLC goes into RUN mode like it should, I wouldn't say there is anything wrong.
its all about self daignostcs from the processor.no need to bother about the LED at power up..if that led's stiil hold means there might be a fault.
Thanks,
Naag.
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
140
I want to connect an AB Micrologix 1000 with my PC through AB 1761-NET-ENI series D module (no other deive in the network). PC TCP/IP settings...
8,292
how to connect thermocouples in micrologix 1000 1761-L20BWA? pleace help
3,487
Hi all, I've been a long time reader on the forums but need to ask for some help. We have many Micrologix 1000 around site and wanted to put...
6,481
Pls can somebody give me link where to download pdf broshure for Allen Bradley 1761-L32BWB series MicroLogix 100 PLC? I`ve been searching trough...
5,158
