how to connect thermocouples in micrologix 1000 1761-L20BWA?
http://en.wikipedia.org/wiki/Thermocouple
Thermocouples produce micro-milli current ranges, not capable of a standard 4-20mA analog input. You would need to use some expansion IO on any of the micrologix range of controllers. But unfortunately I don't think you can expand the 1000.
Perhaps a 3rd party interfacing device would work.
Someone chime in here if I'm wrong.
Hello, We want to start using Siemens TOP connect systems for wiring the PLC cards. We normally use normal analog input cards for thermocouples...
3,795
321
106
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
123
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
356
