Micrologix 1000 inputs voltage
DJH
Jan 2010
Adelaide
Hi can any one tell me how smooth the voltage has to be on the inputs of a 1761-l32bwb? It requires 24vdc. I have 24vac sources can I just use a half wave rectifier or would I need to smooth the voltage further?
I dont know the specific tolerance required. It would stand to reason that raw unfiltered half wave DC would switch the input on for the positive half cycle and off on the negative half cycle. Depending on the point that the scan updated in the CPU it could produce erratic results.
I think you could be safe in using a diode bridge and then a 2200uf@35 vdc at the output(cathode) of the diode.Be sure to fuse this at the anode end of the diode bridge with a proper fuse rating of the device .
remeber to check the dc voltage out with a meter.
Hello everyone, I'm trying to figure out an issue with a MicroLogix 1000 PLC (1761-L10BWA) and I really have no knowledge of these devices or...
17
7,611
Hello. I have a project due in which first, I have built a DVM. Next, I have to interface it with a PLC. The voltage ranges are 0--1.9V and...
5,206
I am using a Micrologix 1000 (1761-AWA) on my PLC trainer. Please understand that I am a beginner, and am building my trainer so that I can...
6,335
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
134
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,258
