MicroLogix 1100 Ethernet Channel configuration
freshmeat
Sep 2017
China
Hi Experts,
I am new to this forum and have a question regarding AB MircoLogix 1100 Ethernet port IP configuration.
As per the ML1100 User Manual (1763-UM001F, page227), there are two ways to configure the MicroLogix 1100 Ethernet channel 1.
•via a BOOTP or DHCP request at controller powerup
•manually setting the configuration parameters using RSLogix 500 Programming Software
I have successfully configure the Ethernet Port by above methods. however, I found a company internal document suggesting the IP address of ML1100 can be modified by using RSLinx.
I have the ML1100 (IP configured, BootP & DHCP disabled) shown on RSLinx, but when I right click on the ML1100; there is no "Module Configuration" option appeared.
The version of my RSLinx (Classic Lite)is 2.59.01 CPR9 SR5 and the ML1100 is 1763-L16BBB B/14.00.
ML1100 is directly connected to my laptop with a single Ethernet cable.
Can anyone tell me if RSLinx can be used to configure IP address of ML1100?
Any suggestion is appreciated.:nodi:
Regards,
Freshmeat
Thank you for all of the replies, so the ML1100 user manual is correct; we have to modify the IP address of ML1100 by BootP or RSlogix500 only.
Regarding assigning IP through keypad, I think that is a feature of ML1400, not ML1100. As ianingram said, we only view the IP on ML1100 but not changing it.
Thanks again everyone, guess I got a document to update......
Freshmeat
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,199
Hi, I'd like to set up a connection between an IX Vision Sensor and a Micrologix 1100 from Rockwell Automation through EtherNet/IP protocol. Does...
1,089
I have a broken Micrologix 1100 here - the serial port is damaged. My only way to communicate is through the ethernet port - but I don't have...
2,895
I am controlling a powerflex 525 over ethernet with micrologix 1100, I have the drive set up and running forward and reverse, I would like to...
2,858
First of all Hi, nice to met you all. I have a problems trying to control my PLC's (1762-L40BWA ser. C and 1763-L16DWD ser. B) with the Panelview...
5,086
