Powerflex 525 over ethernet with micrologix 1100
Fast Ed
Sep 2015
Roscommon
I am controlling a powerflex 525 over ethernet with micrologix 1100, I have the drive set up and running forward and reverse, I would like to monitor the amps the drive is outputting, can anyone please tell me the n address to monitor and do i need to configure the drive in any way, thanks in advance
Hello from Kildare & Welcome to the Forum!
I'm just going to link you to the following Rockwell Automation Knowledgebase technote article which includes all the information and steps you should need to achieve your goal...
566003 - PowerFlex 525: Explicit message setup to read and write to drive parameters
Access Level: Everyone
Depending on whether or not you reply with lots of questions on all that Explicit Messaging, it will prompt the Forum as to your level of experience in using this type of drive/controller application, and whether we may need to not only assist you further in your quest, but also advise you on the potential dangers of "controlling" a PowerFlex 525 drive from an Explicit (non Implicit) controller.
Regards,
George
Hi guys! We have a big project at work where we are migrating from 1305, 1336, 160, 70, and 40 drives to identical PowerFlex 525 models. Most...
888
Hi All, I am working on testing a project with a Powerflex 525, final project will be a 755, and I am trying to reset the Elapsed kWh meter over...
595
I am looking for some help with a project that I am working on to finish my maintenance apprenticeship. Any help would be greatly appreciated. My...
3,286
Good Morning , I have a quick question about the Powerflex 525 embedded ethernet drive. I'm using a CompactLogix 1769-L18 and using Ethernet...
1,764
Good Day Guys, I currently have a set up with 4 pieces of a 22-comm-e with 20 powerflex 4. I would like to move away from the daisy chain...
2,461
