Micrologix 1100 Ethernet Comms with Controllogix
RichardsBay
Aug 2005
Durban
I'm am trying to get data across from a controllogix CPU to the Micrologix 1100. Has anyone managed to do this? I am having some trouble setting up a message instruction between the 2 CPUs.
Help please...
Thanks,
RB
Please post more information so that somebody has a chance of correcting your mistake or providing a hint rather than explaining every part of the configuration from the beginning.
Which controller will be sending the messages ? What configurations have you tried already ?
As Ken said, more information is needed to provide specific help. However, for starters, let me ask you if you have set up the PLC5/SLC mapping in the ControlLogix program. This is the most important step in setting up ethernet communications.
I have created a document that explains the entire process in complete detail. This website does not let me upload large files. If you send me your direct email, I could email that to you.
Purav
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,203
Hi, I'd like to set up a connection between an IX Vision Sensor and a Micrologix 1100 from Rockwell Automation through EtherNet/IP protocol. Does...
1,089
I have a broken Micrologix 1100 here - the serial port is damaged. My only way to communicate is through the ethernet port - but I don't have...
2,899
I am controlling a powerflex 525 over ethernet with micrologix 1100, I have the drive set up and running forward and reverse, I would like to...
2,862
First of all Hi, nice to met you all. I have a problems trying to control my PLC's (1762-L40BWA ser. C and 1763-L16DWD ser. B) with the Panelview...
5,092
