Micrologix 1100, firmware update trouble
lypse
Apr 2018
Denmark
Hello Guys,
I've tried updating my Micrologix 1100 to latest firmware (16)
My PLC, is type 1763-L16BWA Ser. A Rev A, FRN 1
I've tried to update with ControlFlash 15.01.00
I use Windows 10, and is connected with a Serial Cable (with USB/RS232 Adapter) Before I tried the update I could connect with RSLogix Micro, and see the old owners program.
After attempting update, it stops at block 25, the PLC reboots, and the 3 LEDs below power is flashing.
  • Did I brick it somehow, or is there a way out of this? :)
    Thanks in advance for any suggestions.
Code:
Fri Apr 20 21:17:50 2018 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
Fri Apr 20 21:17:51 2018 [SUCCESS] User [LYPSE-X13R2\LYPSE] successfully logged in ControlFLASH.
Fri Apr 20 21:20:40 2018 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\MicroXA.DLL
Fri Apr 20 21:20:40 2018 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\MicroXA.DLL
Fri Apr 20 21:21:16 2018 [-------] Device Path: Current OS version: 1.0
Fri Apr 20 21:21:16 2018 [-------] Device Path: VID=0x0001, PT=0x000C, PC=0x00B9
Fri Apr 20 21:21:16 2018 [SUCCESS] Device Path: LYPSE-X13R2!AB_DF1-1\1
Fri Apr 20 21:21:29 2018 [SUCCESS] Validate:
Fri Apr 20 21:21:45 2018 [SUCCESS] The current logon user [LYPSE-X13R2\LYPSE] is allowed to update firmware.
Fri Apr 20 21:21:47 2018 [SUCCESS] Load Script: C:\Users\lypse\AppData\Local\Temp\ControlFlash\{C7C9E829-7C6A-47A1-91A4-9442B980EEC0}\ML1100_R03R16_Os.nvs
Fri Apr 20 21:21:47 2018 [SUCCESS] Program: Catalog Number = -----------------------------------, Serial Number = 000F73000575, Num Updates = 2, Size = 546916 byte(s).
Fri Apr 20 21:22:14 2018 [FAILURE] Update: Command ignored, controller is not in the correct state.
DTL_E_FAIL, I/O completed with errors
Fri Apr 20 21:22:14 2018 [FAILURE] Update: Error Code: 24 Extended Error Code: 523 Context: 4
Fri Apr 20 21:22:29 2018 [FAILURE] Update: Instance = 1, Size = 485500 byte(s), Chunk Size = N/A.
Fri Apr 20 21:55:08 2018 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
Fri Apr 20 21:55:09 2018 [SUCCESS] User [LYPSE-X13R2\LYPSE] successfully logged in ControlFLASH.
Fri Apr 20 21:55:22 2018 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\MicroXA.DLL
Fri Apr 20 21:55:23 2018 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\MicroXA.DLL
Fri Apr 20 21:55:28 2018 [-------] Device Path: VID=0x0001, PT=0x000C, PC=0x00B9
Fri Apr 20 21:55:28 2018 [SUCCESS] Device Path: LYPSE-X13R2!AB_DF1-1\1
Fri Apr 20 21:55:42 2018 [SUCCESS] Validate:
Fri Apr 20 21:55:47 2018 [SUCCESS] The current logon user [LYPSE-X13R2\LYPSE] is allowed to update firmware.
Fri Apr 20 21:55:49 2018 [SUCCESS] Load Script: C:\Users\lypse\AppData\Local\Temp\ControlFlash\{F362D98F-2D05-4545-9286-4D525AB5027F}\ML1100_R03R16_Os.nvs
Fri Apr 20 21:55:49 2018 [SUCCESS] Program: Catalog Number = -----------------------------------, Serial Number = N/A, Num Updates = 2, Size = 546916 byte(s).
Fri Apr 20 21:55:51 2018 [SUCCESS] Update: Instance = 1, Size = 485500 byte(s), Chunk Size = 242 byte(s).
Fri Apr 20 21:55:51 2018 [SUCCESS] Load Script: C:\Users\lypse\AppData\Local\Temp\ControlFlash\{F362D98F-2D05-4545-9286-4D525AB5027F}\ML1100_R03R16_Os.bin
Fri Apr 20 21:56:09 2018 [FAILURE] Transfer: Illegal command format.
Fri Apr 20 21:56:09 2018 [FAILURE] Transfer: Error Code: 24 Extended Error Code: 272 Context: 4
Fri Apr 20 21:56:25 2018 [FAILURE] Transfer: Illegal command format.
Fri Apr 20 21:56:25 2018 [FAILURE] Transfer: Error Code: 24 Extended Error Code: 272 Context: 4
Fri Apr 20 21:56:26 2018 [FAILURE] Transfer: File = C:\Users\lypse\AppData\Local\Temp\ControlFlash\{F362D98F-2D05-4545-9286-4D525AB5027F}\ML1100_R03R16_Os.bin, Block = 25.
Fri Apr 20 22:21:34 2018 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
Fri Apr 20 22:21:34 2018 [SUCCESS] User [LYPSE-X13R2\LYPSE] successfully logged in ControlFLASH.
Fri Apr 20 22:22:10 2018 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\MicroXA.DLL
Fri Apr 20 22:22:10 2018 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\MicroXA.DLL
Fri Apr 20 22:22:15 2018 [-------] Device Path: VID=0x0001, PT=0x000C, PC=0x00B9
Fri Apr 20 22:22:15 2018 [SUCCESS] Device Path: LYPSE-X13R2!AB_DF1-1\1
Fri Apr 20 22:22:24 2018 [SUCCESS] Validate:
Fri Apr 20 22:22:31 2018 [SUCCESS] The current logon user [LYPSE-X13R2\LYPSE] is allowed to update firmware.
Fri Apr 20 22:22:35 2018 [SUCCESS] Load Script: C:\Users\lypse\AppData\Local\Temp\ControlFlash\{54BE00DD-468E-483C-9A4B-A5C88899755D}\ML1100_R03R16_Os.nvs
Fri Apr 20 22:22:35 2018 [SUCCESS] Program: Catalog Number = -----------------------------------, Serial Number = N/A, Num Updates = 2, Size = 546916 byte(s).
Fri Apr 20 22:22:37 2018 [SUCCESS] Update: Instance = 1, Size = 485500 byte(s), Chunk Size = 242 byte(s).
Fri Apr 20 22:22:37 2018 [SUCCESS] Load Script: C:\Users\lypse\AppData\Local\Temp\ControlFlash\{54BE00DD-468E-483C-9A4B-A5C88899755D}\ML1100_R03R16_Os.bin
Fri Apr 20 22:22:51 2018 [FAILURE] Transfer: Illegal command format.
Fri Apr 20 22:22:51 2018 [FAILURE] Transfer: Error Code: 24 Extended Error Code: 272 Context: 4
Fri Apr 20 22:23:02 2018 [FAILURE] Transfer: Illegal command format.
Fri Apr 20 22:23:02 2018 [FAILURE] Transfer: Error Code: 24 Extended Error Code: 272 Context: 4
Fri Apr 20 22:23:09 2018 [FAILURE] Transfer: File = C:\Users\lypse\AppData\Local\Temp\ControlFlash\{54BE00DD-468E-483C-9A4B-A5C88899755D}\ML1100_R03R16_Os.bin, Block = 3.
Fri Apr 20 22:29:38 2018 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
Fri Apr 20 22:29:39 2018 [SUCCESS] User [LYPSE-X13R2\LYPSE] successfully logged in ControlFLASH.
I see frn 15.00 and 15.02 on AB site. I didn't see 15.01, but all others are for series B controllers and yours is series A.
Hi Mdim,
I'm not so sure, I only search for 1763, and I see version between 10 and 16. I see no different software between A and B series.
I just managed to flash with version 10, it included ControlFlash 8.01.001 and I also changed the baud rate in device manager for the COM port to match the option mentioned by the older ControlFlash. So I will try again to flash version 16 :D
When you download the control flash, just check the compatibility, it should be compatible with ser.A as yours
Finally, managed to flash my Micrologix 1100 to Firmware version 16.
It succeeded with Controlflash 12.00.01 included in Version 15.02 Firmware download.
So it seems likely that Controlflash 15.01.00 will not work with Micrologix 1100, Series A?
Thanks for help mdim, how would I know if if a particular version of controlflash works with a particular firmware/PLC in the first place? :unsure:
Hello, I am pretty new to working with PLCs and am seeking to update a MicorLogix 1100 1763 series A from FRN 3.0 to something newer. I am hoping...
2,383
Hello All, I was recently tasked with updating the firmware on all our Micrologix 1100s to v16. I took processors from the bench, flashed them...
2,662
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
124
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
538
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
195
