MicroLogix 1100 Firmware Update
palmersc
Aug 2020
IA
Hello, I am pretty new to working with PLCs and am seeking to update a MicorLogix 1100 1763 series A from FRN 3.0 to something newer. I am hoping to get it to communicate with the Ignition network I am building. I read that my outdated firmware was likely why I could not get their driver to work with my 1100.
I might have messed up though. At the bottom of this post, I get the below error codes in the log.
In updating firmware, I understand that I need to connect through the serial connector rather than the Ethernet I have been using to program the device. So I was able to get the RS-232 driver configured in RSLinx. With that done, I proceeded to using ControlFlash 12 to update to FRN 15. It began going to work and seemed okay until it errored. The device now shows the power led with the three below flashing and the screen reads as shown in the attached photo. Since then, I have tried Control Flash 8.0, 10.0, and 12.0 with various different firmware versions in hopes that there is some compatibility issue with the Series A I can overcome.
But it seems that something else is wrong. Maybe really wrong. I now can no longer access the device in RSLogix. I think this may have been my fatal error. I did not go into RSLogix to update the system Comms to the Serial connection I established in RSLinx. The PLC still had the Ethernet driver loaded.
Somehow the firmware update got far enough to wipe out the old FRN version but not far enough to begin the update. So now it is stuck in this boot sequence.
I guess my one hope is that since RSLinx still sees the device and all seems oaky there, that there still may be a chance to talk to the PLC.
Please let me know if I can provide any additional useful information. I appreciate your advice on what options I might be looking at here. Thank you.
________________________________________________
08/18/20 19:34:29 [SUCCESS] Load Script: C:\Program Files (x86)\ControlFLASH\0001\000C\00B9\ML1100_R03R15_Os.nvs
08/18/20 19:34:29 [SUCCESS] Program: Catalog Number = -----------------------------------, Serial Number = 000F73***26A, Num Updates = 2, Size = 546452 byte(s).
08/18/20 19:34:33 [SUCCESS] Update: Instance = 1, Size = 485036 byte(s), Chunk Size = 242 byte(s).
08/18/20 19:34:33 [SUCCESS] Load Script: C:\Program Files (x86)\ControlFLASH\0001\000C\00B9\ML1100_R03R15_Os.bin
08/18/20 19:34:50 [FAILURE] Transfer: Illegal command format.
DTL_E_FAIL, I/O completed with errors
08/18/20 19:34:50 [FAILURE] Transfer: Error Code: 24 Extended Error Code: 272 Context: 4
08/18/20 19:36:55 [FAILURE] Transfer: Illegal command format.
08/18/20 19:36:55 [FAILURE] Transfer: Error Code: 24 Extended Error Code: 272 Context: 4
08/18/20 19:36:57 [FAILURE] Transfer: File = C:\Program Files (x86)\ControlFLASH\0001\000C\00B9\ML1100_R03R15_Os.bin, Block = 26.
P.S.
The lines right above the section of the log I posted...
08/18/20 19:33:53 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\MicroXA.DLL
08/18/20 19:33:53 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\MicroXA.DLL
08/18/20 19:34:03 [-------] Device Path: Current OS version: 3.0
08/18/20 19:34:03 [-------] Device Path: VID=0x0001, PT=0x000C, PC=0x00B9
08/18/20 19:34:03 [SUCCESS] Device Path: PALMER-INC!AB_DF1-2\1
08/18/20 19:34:06 [SUCCESS] Validate:
08/18/20 19:34:13 [SUCCESS] Validate:
08/18/20 19:34:29 [SUCCESS] Program: Catalog Number = -----------------------------------, Serial Number = 000F73...
Its been a long time since I updated a 1100 but why cant you use the Ethernet? The firmware does not affect the daughterboard (Ethernet) only the CPU as all AB PLC's
Have you tried downloading the program to the CPU? When you updated the firmware you wiped out the program and the configuration so you will not be able to just click download...
Open the program and click Comms, then system comms, then a pop up window will open, select your driver (DF1) then click the PLC on the right side.... then click download
See if that works
I appreciate it. Your advice might have helped me re-establish connection with the device through the serial port. I remember hitting "OK" and "Online", but did not try "Download" in the "Comms" / "System Comms..." settings. Still new to this, but yes, makes sense to try to get the program back on the PLC.
I want to follow up so that others that run into a similar problem might try what ended up working for me. As a last attempt before calling it a night, I tried another combination of ControlFlash and Firmware version. This is a series A 1100 and what worked in this case was ControlFlash 8.01.001 and FRN 15.2.
Got a couple pics attached. You can see that the serial number and revision were both wiped out. At the completion of the update, all was restored. And Ignition can see the Micro with the new firmware now.
Hello All, I was recently tasked with updating the firmware on all our Micrologix 1100s to v16. I took processors from the bench, flashed them...
2,662
Hello Guys, I've tried updating my Micrologix 1100 to latest firmware (16) My PLC, is type 1763-L16BWA Ser. A Rev A, FRN 1 I've tried to update...
6,538
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
124
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
538
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
195
