MicroLogix 1100, Kinetix 300 communication
NC96
Sep 2017
Denmark
I got an issue while trying to communicate with the MSG instruction from the MicroLogix 1100 to the Kinetix 300. The MSG gives me the error code "d6 - Connection timed out by network".
I tried setting the MSG up as shown in the kinetix manual page 216.
In the sample code libary i tried to download the K300 ML1400 sample code (changed controller to a ML1100), but it dont work either. I get the same error "d6".
I am able to ping both devices, so network should be ok.
Any ideas what could be wrong?
Welcome to the PLCTalk Forum community !
What exact target IP address do you have configured on the Multi-Hop tab ?
Have you verified using a Web browser that the Kinetix 300 is present at that IP address ? I don't like to rely on PING.
Verify also that your MicroLogix and the Kinetix 300 are configured for the same IP subnet.
The kinetix drive is configured to:
IP: 192.168.1.4
Subnet: 255.255.255.0
MicroLogix is configured to:
IP: 192.168.1.2
In the Multi-Hop tab i typed: 192.168.1.4
I have verified that the Kinetix is at 192.168.1.4, i can communicate with it through MotonView
I forgot to mention this is a new setup
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
128
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
538
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
197
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,197
I have a MicroLogix 1100 and it's capable of ac or dc output voltages. What I don't know is how I'm supposed to tell the 1100 to use dc for the...
1,411
