Micrologix 1100 PLC and Wonderware
coopdegrace
Mar 2009
perth
34
Hi All,
Hopefully someone can give me an answer on this one.
I need to communicate to a Micrologix PLC from Wonderware.
Do you know if the Micrologix 1100 PLC has Modbus TCP communications on its in built Ethernet port?
OR (I have no Wonderware experience..) does Wonderware have a driver available that enables it to interrogate a Micrologix PLC through its ethernet port, as I believe Citect does.
Any help appreciated
Cheers
Dear coopdegrace,
All the AB Micrologix processor doesnt have modbus communication. Only selected processors has it.Specially Ml1400 1766-L32BWAA, Series B processor has the inbuilt modbus communication protocol.
Hi coopdegrace,
Just a note - the article and Wonderware North document provided above are from 2009. The DASABCIP 4.0 has since been upgraded, and more recently replaced by the next generation ABCIP OI Server v6.1 (Operation Integration Server). The ABCIP OI Server provides protocol compatibility for:
  • Ethernet
  • ControlNet thru Bridge
  • DeviceNet thru Bridge
  • Data Highway Plus (DH +) thru Bridge
  • Data Highway 485 (DH485) thru Bridge
More information can be found on the Schneider Electric Global Support website - http://softwaresupport.schneider-electric.com.
Regards,
Jeremy
Hello, After searching the web a bit, I am still not quite sure how I should go about wiring up this controller. It is mostly built for 120V AC...
2,040
Hello everyone I have a problem of losing the ip address of the micrologix 1100 and 1400 PLC each time I lose power. the problem is that I...
1,781
Greetings, (My first post) I have a MicroLogix 1100 Processor. I have downloaded RSLinx Classic. I have also downloaded RSLogix micro English...
24
8,950
Hello all, I have a MicroLogix 1100 Series B that I am trying to read data from and into a PLC-5/20 Series D Rev A. I assume this is...
3,699
Hey friends, Need to generate analog signals in MicroLogix 1100. Please help with how to configure the I/O devices. It would be very nice if...
2,027
