Micrologix 1100
montech
Jun 2008
Colorado
30
Hey Guys...HELP!
I have a 1763-L16BBB.Dont have a serial port on my laptop so trying to connect to it with ehternet.I can see the controller in RSWHO in RSlinx 2.51.I can get Data Monitor to read it.
I can get the built in web server to work @ IP 192.168.2.226 but dont know the password.(Changed from fact default)
I have no problem runiing SLC racks on this setup.
My problem is when ever i try to access the controller in RSLogix 500 I get a "not a SLC500 or micrologix controller"error. even tho I go to comms and can see it @ 192.168.2.226 on the AB_ETHIP-1 network.
Any ideas?
What version of RSLogix 500 are you running ?
What is the firmware revision of the MicroLogix 1100 ?
If the MicroLogix has firmware newer than your RSLogix 500 supports, you'll get that error. Check the Release Notes that come with RSLogix 500 to see which new firmware releases and hardware devices are supported by your release.
Thanks s0 much fellas.Updated to RSlogix 500 Version 8(CPR9) and that took care of it.I appreciate you guys helping out a newbie
Have a great day.
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
135
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
540
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
198
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,197
I have a MicroLogix 1100 and it's capable of ac or dc output voltages. What I don't know is how I'm supposed to tell the 1100 to use dc for the...
1,413
