Micrologix 1200 channel 0 resets itself on reboot
plaurent
Feb 2009
NC
23
I've set the channel 0 communications port (this is a two port unit) to 9600 baud to accomodate a display panel connected to that port. On ever power off/on event, the channel 0 port resets itself to 19200 baud, which then requires me to reset the port yet again to 9600.
Can anyone help me understand how to get the 9600 baud setting to stick, even through a power off/on cycle? To my knowledge, nobody (even the gremlins we have) is pressing the button to reset the port.
Is there a memory module installed? If so have you stored the comm changes to it? There is also a write protection check box to prevent changes from a memory module. (see channel configuration)
Hello again. I have a system where I am trying to message between a SLC 5/04 and a MicroLogix 1200 over radio modems. If I start fresh, the...
10,748
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
651
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
508
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
755
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
672
