Micrologix 1200 Communication
Dave Steer
Nov 2002
Devon
27
Hi Everyone
I have a customer with a AB Micrologix 1200 controlling a Building Managment System (BMS). The problem is the customers other BMS equipment is speciality BMS controlers (Trend) and he wants the AB to be able to communicate on the Trend network. The only port the Micrologix has is the RS-232 port, which is being used for a Panelview 300. I believe that this port can be used for Modbus which the Trend can use as well. So the question is, is there any way I can split the one port into 2? 1 for the Panelview (RS-232) and the other for the network (Modbus)?
Sorry this is all a bit vague, but thats all the information I was given.
Thanks all
Dave
How unreasonably lucky you are !
AB has just released a new ML1200R series with two ports. Check it HERE .
Otherwise it would not have been easy to get the functionality you needed.
KEn Roach recently identified a port splitter that might work - TomanTron.
If the PanelView is using DF1 protocol you can use one of the excellent devices from ProSoft. We've used the Prosoft 4102 which has multiple ports that can be individually configured to DF1 or Modbus and Master and slave.
I don't have any prior experience with MicroLogix so the Communication Toggle Button is new to me. We currently have a few MicroLogix that are...
2,241
Hi all I have micro logix 1200 and automation direct panel (EA9-T6CL). I have downloaded .RSS file in micrologix 1200 using 1761-CBL-PM02...
1,810
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,633
Hello All, We have a MicroLogix 1200 series controller on a package in our plant. We need to connect a serial device to MicroLogix 1200 for...
4,652
Good Day All, I've a MicroLogix 1200 and Panel View 300 Micro installed on a package in process and its working fine. PV is connected with 8 pin...
3,648
