Micrologix 1200 failed to find baud and parity
rwinter136
Mar 2018
wisconsin
Hi everyone,
I'm a bit of a beginner with PLCs and I am having a hard time connecting to a micrologix 1200. I'm using a 1761-cbl-pm02 cable and no converter. I've attached a few photos that I hope will help. I don't have an offline version of the program so I can't see how the communication was set up before
Thanks in advance
Change your error checking method selection to CRC.
Also, since you have used the DCOMM button, you can probably just go in and manually set the parameters for your driver to the defaults and it will "see" it in RSWho even if Autoconfig doesn't appear to work.
19200, N, 8, 1, CRC is what RSLogix500 is telling me the defaults settings are when I make anew project with a ML1200 Series C
I am assuming from the title that you are using Autoconfig in the driver setup dialog. Autoconfig is usually pretty reliable especially with a PC that has a native serial port, but it has the legacy BCC error checking as the default when you choose the device category and won't link unless you fix that.
And welcome to the forum!
Thanks for the quick response. I tried changing the error checking method and that didn't work. When you say defaults do you mean what automatically comes up when you configure the driver?
When you press the DCOMM button and it lights up as shown in your picture, I believe the settings will go to what I posted above.
You should be able to set up the DF1 Full Duplex driver with those values, hit okay, then go back to RSWho (the tree view in RSLinx) and expand the newly created AB_DF1 driver and see the PLC appear after a few seconds.
Tell us your exact model and series and I will open the manual on it and see if I am right to assume what RSLogix tells me for a new project is correct.
EDIT: Do you have a USB to serial adapter you can try?
What version of RSLinx are you running?
the plc model is 1762-l40awa ser C
I'm using RSlinx version 2.5
I tried using an adapter and it still would not connect using auto config or manually
Hello, anyone have an idea to help me solve my problem? I have a Micrologix 1200 PLC (1762-L40AWA serie C) and the PLC has lost its program for...
2,168
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
683
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
518
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
763
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
679
