Good Afternoon,
I have a Micrologix 1200 1762-L40AWA Series C rev A with FRN 4 installed, I tried to update it to FRN 12 using the controlFlash during the upgrade on chunk 20 of 782 I get the error "Illegal Command Format DTL_E_FAIL, I/O completed with errors" it created the following log
"7/15/14 15:23:45 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\MicroXA.DLL
07/15/14 15:23:45 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\MicroXA.DLL
07/15/14 15:23:50 [-------] Device Path: VID=0x0001, PT=0x000E, PC=0x002E
07/15/14 15:23:50 [SUCCESS] Device Path: ANDREW-THINK!AB_DF1-1\1
07/15/14 15:23:51 [SUCCESS] Validate:
07/15/14 15:23:51 [SUCCESS] Authorization: Bypass cookie used.
Key: KAM_BOOT_OS
07/15/14 15:23:54 [SUCCESS] Load Script: C:\Program Files (x86)\ControlFLASH\0001\000E\002E\KAM_BOOT_OS.nvs
07/15/14 15:23:54 [SUCCESS] Program: Catalog Number = 1762-LSC , Serial Number = N/A, Num Updates = 1, Size = 189160 byte(s).
07/15/14 15:23:56 [SUCCESS] Update: Instance = 1, Size = 189160 byte(s), Chunk Size = 242 byte(s).
07/15/14 15:24:04 [FAILURE] Transfer: Illegal command format.
07/15/14 15:24:04 [FAILURE] Transfer: Error Code: 24 Extended Error Code: 272 Context: 4
07/15/14 15:24:08 [FAILURE] Transfer: Illegal command format.
07/15/14 15:24:08 [FAILURE] Transfer: Error Code: 24 Extended Error Code: 272 Context: 4
07/15/14 15:24:09 [FAILURE] Transfer: File = C:\Program Files (x86)\ControlFLASH\0001\000E\002E\KAM_BOOT_OS.bin, Block = 20."
What can I do to fix this? I can still see the processor using RSlinx, so I think it maybe salvagable
Thanks,
Andrew
Key: KAM_BOOT_OS
Thanks,
Andrew
