Micrologix 1200 firmware discrepancy
Apr 2020
USA
50
The sticker on the side of my PLC says it is a Series C and FRN 6.
In RSLogix 500 under processor status, the OS FRN shows 0.00 and the OS Series shows A.
Shouldn't these match? Any idea where the discrepancy is?
I need series C in order for modbus comms in this controller. I am unable to download my program to the PLC due to error message; download failed, program incompatible. Was thinking this is the reason.
i would try this.
start a new program,
connect to the plc.
go to the config section
read existing plc configuration and see what it is.
hope this helps,
james
Starting a new program still gives me 0.00 and A for Series and FRN.
I must have a setting or configuration off somewhere. I opened the file that was on the controller when I was given it, and it has the correct Series and FRN numbers.
I don't think I've ever encountered that problem with a MicroLogix 1200. There is a possibility that you've been handed a controller with a failed firmware update that is not usable.
The MicroLogix 1200 has a dedicated FAULT LED indicator on the front: what is its state (off, red flashing, red steady) ?
Can you browse it with RSLinx Classic and right-click for the device properties to see what its identity information says about firmware revisions ? Remember that the MicroLogix 1200 has a "DCOMM" button that puts the Channel 0 serial port into the default DF1 Full Duplex 19200/8/N/1/CRC settings.
The method James describes is something I do with unknown SLCs or MicroLogix: "go online" by uploading the program, and use the Read IO Configuration button to let RSLogix 500 read the identities of the CPU and the IO modules (in a modular SLC).
It is my recollection that the MicroLogix 1200 "Series C" was a firmware change only, unlike the MicroLogix 1400 Series B hardware + firmware change.
i would try this.
connect to the plc.
hope this helps,
james
Looks like when my program failed to download to the controller it put it into remote state. I restarted everything again, uploaded a different program, and the correct specs populate now.
Appears my issue is the controller firmware revision. Rslogix says my program isn't compatible (Modbus master only compatible with FRN 8 or higher). My firmware is 6. Looks like I need to research how to update the firmware.
Hello, anyone have an idea to help me solve my problem? I have a Micrologix 1200 PLC (1762-L40AWA serie C) and the PLC has lost its program for...
2,163
Good Afternoon, I have a Micrologix 1200 1762-L40AWA Series C rev A with FRN 4 installed, I tried to update it to FRN 12 using the...
5,721
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
651
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
507
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
754
