Micrologix 1200 newbie
saudong
Dec 2011
windsor
I bought micrologix 1200 1762 L24BWA to learn at home
my question is: if i only have base plc without I/o rack can i use RX500 to write some logic ladder ? and how can config in Rxlogix 500. Thanks
Welcome to the Forum !
MicroLogix 1200 controllers built-in I/O are considered "Slot 0" in the memory map. When you select the Controller type in RSLogix 5000, the I/O memory locations for the MicroLogix 1200 are pre-defined.
You specifically mentioned the 1762-L24BWA controller. The "B" indicates that the controller has 24V DC Inputs, the "W" indicates Relay outputs, and the "A" indicates 120V AC power.
The "24" indicates 24 total I/O; this controller has 14 Inputs and 10 Outputs.
The wiring can be a little tricky, with mixed common groups and so forth. Print out the Wiring Diagram from the Installation Instructions or User Manual and have it handy whenever you terminate a wire.
The memory addresses of the I/O are I:0/0 through I:0/13 for the Inputs, and O:0/0 through O:0/9 for the Outputs.
Yes, but you can't use the free version, if that is what you are asking.
Thank you for your reply.I used micrologix 500 pro with 7 days Grace.
Ken,Thank you. I will read more and i am sure i will come back to ask more.
Hi everyone! I am new to PLCs and need some help. I can brute force my way through the ladder logic, but the actual PLC installation & wiring...
1,579
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
702
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
520
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
764
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
681
