Micrologix 1200 PLC
teeboonee
Oct 2013
Toronto
I am doing a PF correction and am using a micrologix 1200. I am trying to find the difference between 2 counts from my high speed counter. Is there anywhere that the data from my counter might have been saved or is there another way to find the difference between the two counts?
In the left hand pane of Logix 500, under Controller open Function Files and select the HSC tab. Select and expand (+) to see all of the items associated with the HSC.
Go to the literature library at ab.com and download the manual for your ML1200, if you are using HSCs you'll need to have that info handy.
Thank you, but will that show to time between one count to the next?
The high speed counter on these is simply that. It does not record a time stamp for you to see the difference in time. In fact, there is no native RTC on this processor (you have to buy the RTC module addon). And I don't believe it will resolve time to anything significant enough to calculate power factor. In theory, you could use the interrupt function of the HSC and grab the time from the RTC but once again, not sure if this is sufficient for anything high speed.
How do you program a Micrologic 1200 RTD module using a Micrologic 1400 PLC? I'm using RSLogix Micro to program the ladder logic. I've wired the...
2,846
Which communication cable should I buy to communicate with a micrologix 1200 plc. I have Windows xp sp 2 running on a virtual machine on my laptop...
1,692
So I'm working on writing my first PLC program, and I don't really understand the PLC memory / data files. I see the various things like Integer...
4,016
hello guys. I m new to this blog and i dont know if there is already a thread discussed already about this plc. So i would like to start a thread...
2,434
i have the plc 1762-ow8 micrologix 1200 plc and a slave having rs 485 interface. how do i connect the slave to the plc. the slave is quasar meter...
2,939
