MicroLogix 1200 Software
Feb 2015
NC
18
Hi there, I bought a micrologix 1200 1762-L24AWA from e-bay for $130.
I was under the impression that I could use the free version of RS Logix Micro Starter Lite for this processor. I am getting "This processor is not supported by Micro Starter Lite." Do I need RS Logix 500?
Is there a free software for this processor?
Thanks,
Zach
The Free edition of RSLogix 500 only supports the MicroLogix 1000 and MicroLogix 1100 models.
The MicroLogix 1200, 1400, and 1500 models all require RSLogix 500 Starter or Standard.
RSLogix 500 Starter is less expensive but does not support online editing at runtime. That's OK in your case because the MicroLogix 1200 doesn't support that functionality either.
Thanks for the reply. Stupid question...........any chance RS Logix 5000 version 20.4 will work on the Micrologix 1200? I dont have RS Logix 500
An easy solution if you want to use the free software is to return or re-sell the 1200 and buy a 1100. That is, unless of course, you need a feature that the 1100 doesn't have and the 1200 does.
Ken,
The highlighted Editions, RSLogix 500 Starter or Standard, would suggest they are the minimum Editions required for those MicroLogix controllers. Not quite. You're forgetting one other Edition in the middle...
The free Edition is called RSLogix Micro Starter Lite Edition and as you correctly say only supports the MicroLogix 1000 and 1100.
However, the next available product for the MicroLogix family is RSLogix Micro Starter Edition, and is not free. This will support all of the MicroLogix controllers only. This is the minimum Edition the OP would require to program their MicroLogix 1200.
Next you can go to RSLogix Micro Developer Edition which will still support all the MicroLogix controllers only, but with some additional features.
After that you can move up to RSLogix 500 Starter or Standard Edition which will support all of the MicroLogix controllers and the SLC controllers.
If a user just wants to be able to program all of the MicroLogix controllers then RSLogix Micro Starter Edition would suffice and is much less expensive than RSLogix 500 Starter Edition or indeed Standard Edition.
One supplier's website I've just looked up lists these current prices...
ROCKWELL AUTOMATION 9324-RLM0100ENE RSLOGIX MICRO STARTER EDITION - $141.00
ROCKWELL AUTOMATION 9324-RLM0800ENE RSLOGIX MICRO DEVELOPER EDITION - $509.00
ROCKWELL AUTOMATION 9324-RL0100ENE RSLOGIX 500 STARTER EDITION - $1220.00
ROCKWELL AUTOMATION 9324-RL0300ENE RSLOGIX 500 STANDARD EDITION - $2480.00
ROCKWELL AUTOMATION 9324-RL0700ENE RSLOGIX 500 PROFESSIONAL EDITION - $4290.00
As you can see, the RSLogix Micro Starter Edition is considerably less expensive than RSLogix 500 Starter Edition. Enough so to sway a beginner toward considering purchasing it.
RSLogix Micro Starter Edition also supports Online Editing, but only for the MicroLogix controllers which support this feature. Namely the MicroLogix 1100 and 1400.
So RSLogix Micro Starter Edition (Catalog Number: 9324-RLM0100ENE) would be the minimum Edition required to program a MicroLogix 1200 controller.
Regards,
George
Hello I have a AB MicroLogix 1200 in a machine that I would like to add a couple ladders to the program. What will I need for software and where...
9,301
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
662
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
511
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
757
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
673
