Micrologix 1200 to PLX51-df1-eni router
akosimalakas
Aug 2020
Manila
Guys, need help.
How am I going to use this MSG instruction in RS Logix 500 to communicate in PLX51-df1-eni router.
I already configured the df1 router and its already present in RS-linx.
Welcome to the PLCTalk forum community !
What is your application; are you trying to read or write data from another SLC/MicroLogix family controller on Ethernet, or a ControlLogix/CompactLogix family controller ?
Are you asking for help on configuring and triggering an MSG instruction in ladder logic, or on configuring the DF1 Station address -> IP Address routing in the Prosoft device ?
thank you for your reply sir, I already configured the prosoft device. the problem is I cannot communicate the ML1200 to prosoft df-1 router because it doesn't appear in rs-linx. so maybe I need the MSG instruction in order to communicate in prosoft device.
I need to read data in ML1200 using PLX51-DF1-ENI to send it in scada.
You definitely do not need MSG instructions to communicate with your MicroLogix from a SCADA system.
The configuration of the PLX router looks correct, and it does appear in RSLinx as an Ethernet device. It's the DF1 port and connected MicroLogix that do not appear.
What sort of cable are you using between the PLX router and the MicroLogix ? Does the COMM LED on the MicroLogix ever flicker when you browse the PLX router in RSLinx, suggesting that packets are moving between the PLX and the MicroLogix ?
You might also try configuring the MicroLogix Channel 0 serial port for Source ID =1 instead of 8. While most DF1 Full Duplex Point-to-Point implementations ignore the Source and Destination station numbers, it might be that the PLX router expects the MicroLogix to have DF1 station address = 1.
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
655
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
510
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
755
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
673
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,282
