MicroLogix 1200
surveypay
Apr 2011
FLORIDA
Error 31-Have a machine will not run whilst showing error 31 on a ML1200. Sometimes it will go away after a power re-cycle. Other times it will go away after disconnecting comms from another ML1500, and the two communicate through two 1716-net-AIC module. Checked the manual for error description and it says Internal error,,replace the ML1200 unit? Any better suggestions?
See PDF below. And picture.
Where are you seeing this error code ?
  • error 31.pdf
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
690
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
518
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
763
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
679
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,288
