Micrologix 1400 & 1762-IT4
Salazard
Apr 2012
Vancouver
28
Hi
Need help. I'm new to the plc progamming specifically Allen Bradley PLC. I am planning to create a control for an oven. using Micrologix PLC and 1762-IT4 thermocouple module. Any one who is expert on PID that can share there talent and experience. Maybe a sample code of configuration. A sort step by step procedure that would help me.
Dan
Thanks for your recommendation. That is the first option that i recommend to the owner of the bakery but he want it on the Panelview 600 to control everything. That is why i have no choice but to use a thermocouple module instead of a Temperature controller.
Love it when they want to spend money for no reason....
Search Ron Beaufort and you will find PID setup RSLogix 500
EDIT: Here is one http://www.plctalk.net/qanda/showthread.php?t=16769&highlight=SLC+PID
Dear Sirs, i have a problem with my micrologix 1400 with analog input 1762 if4 . I have set the hardware jumper for Volt and i added the...
2,717
Hello All I have an application using a ML 1400 with 4 analog inputs and a 1762-IF4 expansion card with 4 analog inputs. I have 6 analog...
9,947
hi to all, have anyone tried to communicate Schneider PM800 to a ML1400 through rs485? i am having an issue with it just receiving message...
51
Hey all, first time poster here. I am wondering if anyone has tried using a Keyence SR-X300 barcode scanner to a Micrologix 1400. Keyence sent...
108
139
