micrologix 1400 channel 1
stevedunk
Apr 2006
FNQ
52
hi,
i am implementing a process controlled by a micrologix 1400 monitored by a HMI over proface ethernet radio,
i need a means of monitoring the channel 1 comms and implementing an orderly shutdown of the process at the PLC if there is a loss of communication between HMI and PLC.
i have had a look, i dont see anything obvious, perhaps someone has a thought on this.
thanks
steve:wish:
stevedunk;543762 i need a means of monitoring the channel 1 comms and implementing an orderly shutdown of the process at the PLC if there is a loss of communication between HMI and PLC. steve:wish:[/QUOTE said:
Can you have the PLC monitor the seconds on the HMI? when they stop updating comms are lost.
Magelis HMI and yes i'd considered monitoring time.
I was looking at using the status file in the 1400 for simplicity,
i will try ES1:5/0 bit and see if it solves my problem.
thanks
Stevedunk,
Are you still looking to do this?
There's a feature built in to Vijeo Designer for each PLC driver called the Dialog Table. One of the functions you can use is Communications Control. I use this to monitor comms.
This function is a 16 bit word that monitors the Dialog Table for proper operation and ensures the Dialog Tables are synchronized. The value of this word is 0 when the target machine is powered up and then never takes the value 0 again. It increments by 1 during each processing cycle. If the word rolls over, the value changes from 65535 to 1 without passing through 0.
If you're interested in more info on how to set it up, let me know.
G.
hey,
i only just saw your reply, thanks for that , i would be interested in your implementation, i will have a look at this in the help in the meantime.
Hi stevedunk,
I'm not sure if you got any further with your project, but I've just replied in another thread which reminded that you had asked for something similar a while back and I'd forgotten to get back to you. Apologies for that. The attached zip in the thread linked below includes the Communication control that you were interested in...
Clock Sync ~ MicroLogix 1400 to Magelis STU HMI
Regards,
George
I been tasked with setting up communication between a heating cooling unit manufactured by Advantage Engineering and a Microloagix 1400 plc. The...
2,517
Hello guys, Can any one please share the communication diagram of Micro logix 1400 channel 2 RS 232C pin wiring configuration...
6,673
hello friends if i am communication my ML-14000 with microcontroller serially via channel-2 then what commport number I should mention in my...
1,949
Is it possible to download an RSLogix 500 application to the MicroLogix 1400 via Channel 1, the Ethernet Port? If so, how? I'm in the field...
7,453
34
