Micrologix 1400\Red Lion Enet comms
wdd0422
Nov 2003
100
Hey everybody, can't seem to get this working. I have a Red Lion G310C210 connected to a Micrologix 1400 via Ethernet. When I push the buttons I have programmed the output comes on only momentarily even though I have the action set to toggle in the properties on the Red Lion. Also the indicator lights I have on the page do not change state. I am using 2 State, Red = off and Green = on and they stay Red even with the output on.
If I take the PLC out of run mode the buttons toggle correctly. Red Lion says this indicates the problem is on the PLC side. I also am communicating with a fanuc robot using explicit messaging and this works correctly. The PLC IP address is 10.101.80.3 The Red Lion is 10.101.80.4 and the robot is 10.101.80.5
Could this have anything to do with the explicit messaging connection to the robot?
I have included a zipped copy of the PLC program and a screen shot of the Red Lion comms configuration.
Thanks in advance
Bill
  • COREBACK VER1.0 .RSS.zip
Thanks in advance
Bill
I can't open the file right now - I loaned out my Configuration Laptop, but it seems like something in the PLC program is turning the bits back off after the Display turns them on. Do a search in the PLC for the Bits that you are accessing in the Display.
Also, post the Bit Addresses that you are accessing for your pushbuttons so someone who *can* open the PLC file can do the search for you too.
From a quick look, I think that it's a conflict with the MSG instructions.
If you're addressing the Red Lion Flag tags to bits in the B3:3 through B3:12 range, the MSG Read (MG11:1, Read Assembly) from the robot is going to write over them every few milliseconds.
That's just a guess: you need to post details of the Crimson 3 file and which addresses you're addressing those pushbutton objects to.
B3:11/0 thru B3:11/6 are the push buttons. The bits I am using for indicators are I:1/1, I:1/7 and O:2/0. I tried to upload the zipped .cd3 file but it was too big. Thanks
Ok, I'm overwriting the B3:11 bits, any idea why the indicators are not working? Thanks again
MicroLogix physical I/O addressing can be tricky, and I recall some subtle issues with the way Red Lion addresses Data File 0 and Data File 1. I'm not sure it's worth the time to sort it all out.
The simple and easy (and recommended) way to work around this is just to copy the Input and Output data tables into a Bx:yy or Nx:yy data table, and address those from Crimson 3.
For large file transfer, I recommend DropBox, Google Drive, or Microsoft SkyDrive. I use DropBox myself.
I like those because then we can remove the files when the discussion is done, and not burden the storage capacity of the PLCTalk server.
I an new to this: I am trying to finish a project. Here is the tagname Data type Address Controller PUMPA_XS...
3,713
I am having trouble communicating a set of alarm tags from the micrologix 1400 to the crimson software. All the other tags read just fine and give...
1,653
Hi guys, it's the noob again. So i'm currently in the middle of communicating between a Micrologix 1400 PLC (programmed via rslogix 500) with a...
4,797
Hello Everybody. Can some body let me know whether a Servo drive can be controlled through Ethernet or devicenet using Micrologix 1400 PLC? if yes...
2,948
I am using a Data Station Plus with Crimson 3.0 and connecting to a AB Micrologix 1400 PLC via Ethernet. The issue I am having happens randomly...
3,000
