Red Lion MicroLogix 1400 communication
FlyinRedLion
Aug 2016
Toledo
I am having trouble communicating a set of alarm tags from the micrologix 1400 to the crimson software. All the other tags read just fine and give the correct value but the alarms (which are set as integers) read "n/a". I am able to ping both the HMI and PLC from my computer and everything is connected through a switch. Everything else works just fine except these data tags, any help would be appreciated, thank you.
For the data tags, under format tab the format type is Numeric. Under the data tab I have manipulation: none, treat as: default integer, access: read and write.
Hey thanks for your help just wanted to let anyone who reads this know I fixed the issue and it is working properly now. I had to go to RSLogix and go to the Data File for the respective alarms/data tags. In the data file I went to properties and increased the number of elements to match the amount of tags.
Hi guys, it's the noob again. So i'm currently in the middle of communicating between a Micrologix 1400 PLC (programmed via rslogix 500) with a...
4,797
Hi guys, i'm pretty much a beginner to programming in general and i have been tasked with trying to get a micrologix 1400 PLC to talk to a...
30
12,651
I'm working with the combination of a Micrologix 1200, a Data Station DSPSX000 and a Keyence SR-1000 scanner. My code in the data station is...
3,025
Has anyone ever done a red lion hmi to a micrologix 1500 using a 1761-net-eni module? And if so give me some details, please Looking at a...
1,756
Hey everybody, can't seem to get this working. I have a Red Lion G310C210 connected to a Micrologix 1400 via Ethernet. When I push the buttons I...
2,592
