deathbysnusnu
I apologize for the elementary content of my question. I have just started and I have been trying to do some of the examples in the manual, but I keep getting error messages.
1) On RSLinx, the only port I can use is COM1 (set to SLC-CH0/Micro/Panel/View). If I try to change to COM2 (using a Null Modem cable), it says that "re-configuring the port has failed". If I delete it and try to start over by adding a new driver type using COM2, it says that it fails to configure because the COM port is already in use. I do have both COM ports connected to the PC. I'm wondering if I must use COM1 when adding a driver configuration or if there's a problem with my COM2 connection.
2) If I try to change Channel 0 to ASCII, when I try to download to the PLC it says that "Communication configuration is different. * Warning * Loss of communication on CURRENT channel (CH0) will occur. *Warning* Loss of communication on CURRENT channel (CH0) MAY occur. Accept new configuration?". I find this quite confusing because according to the manual I must use Channel 0 in the ASCII instructions, but when I try to configure Channel 0 to ASCII, it pops up error messages.
3) When using the AWA instruction, I cannot change the contents of the source. I wrote ST14:0 as the address and it does appear in the Data Files, but I cannot write anything to it.
4) Also in the AWA instruction, I wrote R6:0/EN in the Control field but I get the following error message: "Address must be specified to the element level".
Any hint to the right direction is appreciated. Thank you very much
