MicroLogix 1400 Series B - RTC resets to UTC
anils
Sep 2015
Mackay
Hi There,
We seem to be having issues with one of our MicroLogix 1400. It appears that after certain days, the RTC time automatically resets to UTC (this happened last Sunday again). This causes issues with our flowmeter reading resets and hours of operation of pumps.
Have we missed any settings which may be causing this issue? Any help will be really appreciated.
Regards,
Anil
Hi Mickey,
Thanks for your reply, I have checked in the instruction sets as well there are no other system writing to the RTC. I can only see couple of RTC comparisons instructions.
However there is a Grundfos PLC which writes to this PLC (attached Message files, which I am not so much familiar with).
Regards,
Anil
Can you post the program? Zip it first.
You normally can't write directly to the RTC words but there might be an integer being written to and a move instruction writing that to the RTC words.
Zipped file
Hi Mickey,
Please find attached the zipped file, just to inform you the RTC time stays on local time for few days. Last time i updated the code and syncronised the time on 22 Sep 2015 and the RTC reverted back to UTC on Sunday 27 Sep 2015. This is not the first time this has happed, only now we have added the pump control times based on RTC which makes it critical.
Thanks again for your time looking at this, really appreciated.
Regards,
Anil
I'm not at a PC with the software at the moment will take a look later.
Hopefully someone else will.
I don't see anything in the program, but that still does not rule out a SCADA/HMI system or a PC from writing to the RTC.
Is there one connected to the PLC?
Firsts of all to make it clear I am novice at programming and controllers. I was called to a costumer who has four machines that do identical...
1,524
Hello. I am having an issue trying to read data from the flow sensor model FL-608 (Digiten) in my micrologix 1400. I read that i have to use a...
1,861
Hello people!, I finally was able to get the job done with modbus in my AB ML 1400, now my question is, I´m receiving correctly the information...
1,852
Hi there folks!, I really want some support regarding a damn modbus connection trough channel 1 TCP modbus in my micrologix 1400 b series, I did...
1,941
Hi! I have a setup where a sensor senses an object and sends a signal to the PLC. The PLC has to send an ASCII character to the PC for triggering...
1,115
