MicroLogix 1400 to CompactLogix Comm
intellimation
Oct 2016
Ohio
I have a ML 1400 that will be talking to a CL L18ER. N13 is data to be sent from ML to CL and N14 is data from CL to ML. The CL is utilizing SLC type Reads and Writes. Do I set up the messaging to utilize N13 & N14 in my MG data file. I was not able to find any help on how to fill out the data table. My help file locks up when I try to access the "MSG Setup Screen (ML1100 and ML1400)" under "MSG" instruction help. I also assume I need to set up an RI file. How many elements do I need in it? Where do I find help on what the various fields are for it?
I could not find how to edit my post, so this is an additional question related to it. Do I need both a Read and Write to pass all of the data or one or the other.
You can do it any way, but most agree it is best to set them both up to read. The routing information as I recall, is a "2, xxx.xxx.xxx.xxx" where "x"s are your IP address. You need to set the option in you CPX to "Map SLC addresses" for the tags that the ML will read from the CPX. You pick what tags will be seen as N13 or whatever by the ML.
Hi all I'm trying to setup a MSG connection (which I'm not familiar to) between a CompactLogix CPU (L310ER) and a Micrologix 1400 CPU. At the...
809
Hi everyone, Brief overview of the issue: I have a CompactLogix (pt No:1769-L36ERM) that is connected to a MicroLogix 1400 (Pt no: 1766-L32BXB)...
4,297
Hello Everyone, I am trying to pull a few data table points from a MicroLogix 1400 L32AWA Controller into a CompactLogix L30ER over ethernet. I...
1,595
Hi! We sell control cabinet equiped with Micrologix1400 CPU and PanelView Plus 6 700 HMI and a powerflex 4m communicating with modbus to the PLC...
2,717
PowerFlex 525 - can you access the parameters from a MicroLogix 1400 & CompactLogix Good Morning , I have a separate stand alone machine...
3,337
