micrologix 1500 28bxb plc analog programming
Nagadev
Feb 2015
We are using Micrologix 1500 plc in high temperature furnace where temperature to be reachd is approx 2000 celcius. heaters cant be continuously ON , since there is no analog I/P in CPU , operator wil turn on heater fr every 100 degree increase and switch off fr stabilise for 15 mins and turn on again for another 100 degree increase.I have planned to connect expansion analog module to measure and attain the temperature in automation.which module is apt for this analog module(1769- IF4)[FONT=&quot][/FONT] r temperature module(1769- IR6). how to program the same. please guide me for solving this..
I let someone use my Micrologix 1500 1764-28BXB to practice on, They accidently put 120VAC on it. I would like to repair it if I can. I have taken...
2,506
Hello all, I'm designing a 24 VDC system using a Micrologix 1500. There are 2 options for the base unit: 1764-24BWA —Twelve 24V DC inputs and...
2,928
89
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
107
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
921
