Micrologix 1500 and Festo Devicenet module
robw53
Nov 2009
south yorks
515
Hi guys,
i am after some advice at work there is a piece of kit which uses a ML1500 and has connected via devicenet 3 x festo input module CP-E16-M12x2 5POL which are nodes 1, 2, and 3 and have sensors feeding them.
if i was to add a second I/P Module what would i need to do to give it a node number for the 1769-SDN see it, and also if i was to add sensors exactly how would i assign each sensor i add to the module its own address i.e I:3/40 for example?
i have looked through the manuals but doesnt give anything that can help me.
regards
Rob
I have only used devicenet with SLC CPUs, but I would expect the ML to be similar. If so, you'll need to set up the scanlist in RSNetworx for devicenet with your changes. To download to the scanner, you'll put the ML1500 in program mode first (or turn off the devicenet enable bit).
85
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
106
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
918
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,210
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,429
