micrologix 1500 - blink light
VJTX
Oct 2007
TEXAS
126
I would like to blink a light, according to the value in N7:1, which can be 0,1,2,3 only.
so, if value is 0, light stays off.
If value is 3, light blinks 3x, stays off 2 seconds, blinks 3x, etc.
if value is 2, light blinks 2x, stays off 2 seconds, blinks 2x,etc.
if value is 1, blink once, off 2 seconds, blink 1, etc.
Any one have a simple solution?
VJTX,
i suggest setting up your logic first using the timer logic to make it flash one time and then reset. then set up a counter to control the number of flashes based on the number in the
n register being moved to the preset address.
regards,
james
126
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
123
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
939
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,220
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,442
