Micrologix 1500 HIgh Speed Counter Enabling
Hey there.
Copy this an paste it in Logix500 software.
SOR OTE HSC:0/UIE EOR SOR OTE HSC:0/FE EOR SOR OTE HSC:0/CE EOR SOR HSL HSC0 1 0 1 0 EOR
It's work at my mircologix 1500..
Hello, I am running a Micrologic 1500PLC (has 2 high speed counters) and I am using the HSC1 function. How do I specify which input (4-7) to use...
6,032
I need to calculate the rpm of an object that has an encoder on the the shaft and will interface with the 1500. What is a good formula? And also...
6,538
130
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
125
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
945
