Micrologix 1500 hsc with 3 encoders
aedaowz
Oct 2012
baja california
Hello All:
I have a Micrologix 1500, 1764-24BWA, 1764 LRP procesoor unit.
I want to know if is possible use 3 encoders in ML1500 one of them using the HSC on the base ML1500 unit and the others using
1769-HSC module.
Hello All:
1769-HSC module.
Yes, it is possible, provided that the encoder signals are electrically compatible with the inputs.
Hi, so I'm having this problem. I have a motor's quadrature encoder connected to a PLC input. When turning the shaft of the motor by hand, the PLC...
1,574
Hi, everyone. I am having problems with HSC:0 in ML1500.My FE and CE functions are enabled and PLC keeps faulting as soon as I put him to...
2,784
Have not figured out how to get a triggered output from HSC:0 Mode 0, "0 Up Counter - The accumulator is immediately cleared (0) when it reaches...
1,939
I have a machine that I'm thinking about installing a PLC to control it's functions. The machine uses a single output pulse generator attached to...
2,928
Hi all, Before I ask my question, a list of hardware may assist in the search for a solution. Micrologix 1500 Base Unit: 1764-24BWA Ser B...
11,889
