Micrologix 1500 HSC not counting properly when motor is running.
Avenger1979
Feb 2014
California
Hi, so I'm having this problem. I have a motor's quadrature encoder connected to a PLC input. When turning the shaft of the motor by hand, the PLC counter that tracks the input pulses counts properly. However, when the motor is running, the counter doesn't properly count. It misses most counts, and when it does catch one, it appears random. I have a feeling that this could be a problem caused by the Input Filter not being set correctly, but I am unsure. Can anyone else shed some light on this issue?
what pulse isn't counting there is usually atleast (3) A+,B+ and Z pulses. sometimes A-, B-,Z- aswell. Also what is the PPR. If the A+ isn't working use the B pulse its 90 degrees out of the A, the Z pulse is only the home pulse so if your watching that you will only that once ever 360 degrees.
Hello All: I have a Micrologix 1500, 1764-24BWA, 1764 LRP procesoor unit. I want to know if is possible use 3 encoders in ML1500 one of them...
2,215
Hi, everyone. I am having problems with HSC:0 in ML1500.My FE and CE functions are enabled and PLC keeps faulting as soon as I put him to...
2,784
Have not figured out how to get a triggered output from HSC:0 Mode 0, "0 Up Counter - The accumulator is immediately cleared (0) when it reaches...
1,939
I have a machine that I'm thinking about installing a PLC to control it's functions. The machine uses a single output pulse generator attached to...
2,928
Hi all, Before I ask my question, a list of hardware may assist in the search for a solution. Micrologix 1500 Base Unit: 1764-24BWA Ser B...
11,889
